The user can specify different accuracy values for reporting the fall using the ACCURACYLEVEL value command (where value can be zero, 1 or 2). The accuracies the user can specify are:
1/16”/10’
1/16”/100’
>- FALLinglines -+- DEG --------.
| | |- RATio ------| | | |- PERcentage -| | | |- GRAds ------| | | |- IMPerial ---| | | |- METric -----+- value --. | | | | | |- ACCuracylevel value -. | | | | | ‘----------+-----------------------| | | ‘- OFF -------------------------------------------+-> |
