Specifies dimensioning style.
String dimensions, which are plotted by default, are measured sequentially from each relevant point to the next. The relevant points are:
Composite dimensions ignore dimensions over which the fabricator has no control, particularly the sizes of individual components. Components which are directly connected to the each other are therefore dimensioned as though they constitute a single composite item.
The user can display overall dimensions in addition to string or composite dimensions. The default standout for overall dimensions is 16mm. Overall dimensions are taken:
By default, support/hanger dimensions are on the same side as string dimensions, but they can be on the opposite side. The default standout for support/hanger dimensions is 6mm.
