ISODRAFT
Command Reference Section
: DIMALL
DIMALL
Function:
Dimension to all component connection points.
Description:
String dimensions are measured sequentially from each relevant point to the next. Relevant points may include component connection points (welds, screwed and compression joints) depending on their shop attributes.
If the value of DIMALL is OFF (default), then the string dimensioning of components is dependent on the shop attribute of the associated component connection points: e.g. SHOP welds WILL NOT be considered as relevant points with regards to string dimensions.
If the value of DIMALL is ON, then the string dimensioning of components is independent from the shop attribute of the associated welds: e.g. SHOP welds WILL be considered as relevant points with regards to string dimensions.
Examples:
DIMALL OFF
DIMALL ON
Related Commands:
DIMENSIONS
Command Syntax:
>---DIMALL---+--- OFF ----.
'--- ON -----+--->
Querying:
Q DIMALL
Q OPTIONS
