Generates and plots isometric drawings and material lists.
More than one pipe or spool drawing can be specified in a single DETAIL command. The pipes can be specified individually, as a high-level element or group, or as members of the Detail List (refer to ADD and REMOVE commands).
Groups of components such as blanking flanges, level gauges, relief valves, etc., can be modelled on the basis of one Pipe per Nozzle, or per group of Nozzles if connected (such as a level gauge piped between two Nozzles). Disconnected branches in the same pipe on different nozzles cannot be grouped. The collection of pipes can then be detailed as equipment trim.
