ISODRAFT
Command Reference Section
: CUTMARKS
CUTMARKS
Function:
Draws cut marks at each corner of the overall sheet area.
Description:
The CUTMARKS command draws right-angled cut marks at each corner of the overall sheet area. When multiple plots are defined on the same drawing sheet, cutting marks will be superimposed. The default is CUTMARKS ON
Figure 2:1.
The location of cutting marks
Figure 2:2.
Cutting marks on multiple plots
Examples:
CUTMarks ON
CUTMarks OFF
Command Syntax
>--- CUTMarks ---+--- ON -----.
‘--- OFF* ---+--->
Querying:
Q CUTMARKS
Q OPTIONS
