value is the minimum grip length. It may be input in mm or inches.
logical expression may be any logical PML expression, from the ‘PML 1 Expression Handler’. For more details refer to ‘expressions’ in the on-line help. This syntax may be used repeatedly to build up an unlimited number of rules.
QCUTBack RULE <int>
Outputs the rule identified by the <int> number.
