ISODRAFT
Command Reference Section
: CHECK
CHECK
Function:
Creates a transfer file.
Description:
The CHECK command extracts isometric data from the Design and Catalogue databases and creates a transfer file.
The extended CHECK AS ... option allows the user to check a complete system isometric with a single command.
The extended CHECK AS EQUIPMENT ... option allows the user to check a collection of pipes as equipment trim.
If a Pipe is detailed with repeatability on, split points can be stored in the DESIGN database. In this case, individual sheets can be added to the Detail List. Refer to REPEATABILITY command.
The capability to CHECK Pipe Spools (PSPOOLs) and Pipe Spool Lists (PSLISTs) is available in ISODRAFT.
All of the functionality available to CHECK PIPEs and BRANCHes in earlier versions of Isodraft is now also available to CHECK PSPOOLs and PSLISTs. Such PSPOOLs and PSLISTs are created in the Pipe Production Checks utility in the Design module and, after their creation, they are visible beneath the owning pipe in the Model Explorer. Then they are subsequently also visible in the Model Explorer in the Isodraft module. The PSPOOL or PSLIST may be made the Current Element (CE) and then CHECKed in the usual way.
A second way in which PSPOOLs and PSLISTs may be CHECKed is by making them members of the Detaillist. This is accomplished using the usual ADD/REMOVE commands which are already available for adding and removing Pipe and Branch elements of the Detaillist.
Examples:
CHECK /SITE2-1 /PIPE-2-2-1
Checks named elements only.
CHECK ALL
Checks the current Detail List (refer to ADD and REMOVE commands).
CHECK /SITE2-1 /SITE2-2 AS ’REFINER’
Checks the two named sites and combines the plot information into a single system isometric with the drawing title ‘REFINER’.
CHECK SHEETN 2 /PIPE-2
Checks sheet 2 of PIPE-2.
CHECK SPOO 2 /PIPE-4
Checks spool 2 of PIPE-4.
CHECK SPOO 2 OF 3 /PIPE-4
Checks spool 2 of sheet 3 of /PIPE-4.
CHECK ISO BASEFLOOR /SITE2-1 /PIPE2-2-1
Checks the named elements of drawing BASEFLOOR.
CHECK PSPOOL2 OF PSLIST1 OF PIPE /013-0001-A150-100
Checks a single PSPOOL.
CHECK PSLIST1 OF PIPE /011-0001-A150-100
Checks a PSPOOL list.
Related Commands
ADD DETAIL REMOVE SPOOLNUMBERS
Command Syntax
>- CHeck -*- <gid> --------------------------------- |
|- ALL ------------------------------------|
|- SHEETNumber -+- integer -. |
| ‘- SINGle --+----. |
|- SPOOl -+- integ -+- OF integ -| |
| ‘-- text --------------+- <gid> -+- AS -+- text-----------.
| ‘------+- EQUIpment text-|
‘-- ISOdrawing - <gid> ---------------------------------------------+->
Restrictions:
The maximum number of element identifiers allowed in a CHECK command is 100.
A maximum of 20 CHECK commands are allowed for a single pipe (sheets or spools). The maximum number of items for any single pipe (sheets or spools) is 20. The user can only check sheets for a Pipe which has previously been detailed with Repeatability on, so that split points have been stored in the DESIGN database. Refer to REPEATABILITY command. Sheets and spools can be specified in the same command as normal pipes.
Querying:
Q DETaillist
Shows the current content of the Drawlist.
