ISODRAFT
Command Reference Section
Command Summary
: Isometric Drawing
Isometric Drawing
COMMAND
Brief description
ANGLEACCURACY
Allows the user to specify the degree of accuracy for the reporting of angles.
ATTANAME
Specifies the ways in which support ATTAs are identified.
AXES
Specifies the coordinate system to be used for showing 3D positions on drawings.
BENDRADIUS
Specifies when radii of pulled bends will be shown and in what units.
BORES
Allows the user to specify the units for input of pipe nominal bores.
CHARHEIGHT
Specifies the character height to be used for annotating text on drawings.
CODECP
Allows the user to specify the precision to which Imperial decimal coordinates are expressed.
COFORMAT
Allows the user to specify the format of the coordinates output on isometrics.
COIMPP
Allows the user to specify the precision to which Imperial fractional coordinates are expressed.
CONTINUATIONSYMBOLS
Plots continuation symbols where pipes are connected to nozzles on Plant equipment.
CONTNOTES
Specifies continuation notes at the end points on drawings for when the connection goes to another isometric.
CONTSHEETS
Allows the user to specify that the sheet number of the continuation sheets be shown
CONTWELDS
Allows the user to plot welds on the current isometric that are to belong to another drawing.
COORDINATES
Specifies the drawing locations at which spatial coordinates are shown.
COUNITS
Allows the user to specify in which units the coordinates are to be expressed.
DIMALL
Dimension to all component connection points.
DIMDIST
Specifies the ‘standout’ distance, between dimensioning lines and pipe/ component centrelines.
DIMENSIONS
Specifies dimensioning style.
ELEVATION
Specifies whether or not elevation coordinates are to be shown.
FALLINGLINES
Defines the maximum rate of fall allowed in a pipeline before it is shown as a skew.
FALLSKEWS
Controls how dimensioning boxes for skewed/falling pipelines are shown.
FIELDSCREWED
Defines what symbol is to be used for a FIELD screwed connection.
FIELDSOCKETWELD
Defines what symbol is to be used for a FIELD socket weld.
FLOWARROWS
Allows flow arrows to be shown on isometric plots.
INSULATIONCONTROL
Specifies whether or not insulation is to be plotted.
LEGLENGTH
Allows the user to specify the plotted leg length of elbows, tees and crosses.
LINETHICKNESS
Allows the user to control (optionally) the thickness of line used to represent piping.
MESSAGEACCURACY
Controls how arrowed messages on the isometric are positioned.
OUTCOM
Defines the style in which attributes are shown on the isometric drawing area.
OVERALLSKEWS
Allows the user to specify whether triangular skewboxes are shown as overall skewboxes across branches, or as separate skewboxes between branch connections.
PICTURESCALE
Allows the user to set the scale of the isometric drawing.
PRECISION
Sets bore dimensions to be nominal or actual.
REFDIMENSIONS
Switches the display of reference dimensions on and off.
REPEATABILITY
Creates split ATTAs at automatically generated split points.
SKEWBOX
Controls how skewed piping is shown.
SPECBREAK
Specifies the level at which a change of pipeline specification is noted, and which changes are shown.
SPLIT
Controls the number of drawing sheets used when a pipeline is split over more than one sheet.
SUPPORTS
Defines whether support positions are shown and are dimensioned as overall or string dimensions.
TAGGING
Allows the user to identify individual components on the isometric plot by means of name tags.
TAPPING
Sets the scale of the tapping leg and switches tapping leg dimensions and coordinates on and off.
TOLERANCE
Specifies the maximum misalignment between components regarded as having the same axis.
TRACINGCONTROL
Specifies whether or not tracing is to be plotted.
TRUNCATE
Stops rounding remainders of dimensions being added to the next dimension.
TUBESPLITS
Controls how splits in tube are placed.
UNITS
Specifies units of measurement to be used for ISODRAFT’s output.
WELDANGLES
Allows configuration in which one pipe is welded to another pipe or component such that the flow directions of the two objects are non-parallel.
WELDID
Allows the user to identify individual welds on the isometric by name.
WELDNUMBERS
Controls numbering the welds on an isometric.
WELDTYPE
Controls which types of end connection are shown on drawings.
ZEROLENGTH-SKEWS
Allows the user to connect a vertical Branch to a falling line.
