ISODRAFT
Command Reference Section
Command Summary
: Materials List and Reports
COMMAND
Brief description
ATTEXTS
Defines selection rules and expressions (typically attribute values) for appending attached text to descriptions in material lists.
CLLENGTHFILE
Specifies that a pipe centreline length summary, with or without an insulation centreline summary, should be output as a report.
CUTPIPELISTFILE
Produces a customisable report giving details of all cut pipes in the isometric.
CUTTINGLIST
Defines a table in the material list showing details of all the cut pipes in the isometric.
DELIMITER
Specifies which character ISODRAFT recognises as the itemcode suffix delimiter.
DTEXTS
Controls the material description part of the item description.
EQUIPMENTNUMBERING
Controls numbering of items on materials list for an equipment trim isometric.
INSTNAME
Allows the user to define how instruments are described in the materials list.
ITEMCODE (1)
Allows the user to label certain types of fitting with their itemcodes on the isometric drawing.
ITEMCODE (2)
Specifies whether or not specification names are to be included in material list itemcodes, and whether items which have the same itemcode except for the specification name and suffix are treated as the same item.
KEYS
Allows components with specified SKEYs to be treated like instruments.
MATCONTROL
Creates a material control file.
MATERIALLIST
Allows the user to control whether the material list is drawn on the isometric and alter the display format if required.
MATLISTFILENAME
Specifies the name of the file into which the materials list can be saved.
MTEXTS
Controls the complete material description part of the item description.
SUPPORTFILENAME
Specifies the name of a file into which the schedule for pipe supports is saved.
WASTAGEAREA
Defines wastage areas that can be given different wastage factors for cut pipe lengths.
