ISODRAFT
Command Reference Section
Command Summary
: Piping Components in ISODRAFT
COMMAND
Brief description
CUTBACK
To make sure there is sufficient length between a pulled bend and the end of the pipe to be gripped by the bending machine and that a pipe with a threaded end is long enough to be gripped by the threading, machine.
LOOSEFLANGEALLOWANCE
Allows the user to specify an additional length on cut tube to compensate for field-fitted welds and loose flanges, where the ALLO attribute has not been set.
