ISODRAFT
Command Reference Section
Command Summary
: MODEL Requirements
MODEL Requirements
COMMAND
Brief description
JOINTNUMBERS
Allows the user to display the joint numbers created in SPOOL on the isometric.
MATERIAL LIST PARTNUMBERS FROMDB
Allows the user to select whether to use the part numbers created by SPOOL.
PBENDNUMBERS
Allows the user to display the pulled bend numbers created in SPOOL on the isometric.
SPOOLNUMBERS FROMDB
Lets the user specify whether to use the numbers created by SPOOL or let ISODRAFT number the spools itself.
WELDNUMBERS FROMDB
Lets the user decide whether to use the numbers created by SPOOL or let ISODRAFT number the spools itself.
