A column that may be included is the OWNER column. If this column is present, it must contain the name of an existing element that owns each imported item when it is created. The owner name is ignored if the imported item already exists – it is not possible to change the owner of existing Equipment by using the OWNER column. If the OWNER column does not exist in the file, then the owner is the current location in the DESIGN DB hierarchy at the time that the file is loaded and analysed. In this case, the current database element at the time that the file is loaded must be able to contain imported elements.
