DRAW Reference Manual
Labels
Create and Manipulate Labels
: Label Views
Label Views
Labels (GLABs and SLABs) can be applied to Views, allowing View names and scales to be applied easily. The Label is associated with the View by setting its DDNM attribute to the View, either directly or using the ON syntax.
Note that if an explicit POS attribute is set, it is not overwritten by the ON command, meaning that the position of the label in the canvas does not change to the centre of the view.
Example:
DDNM View
ON /View99
