DRAW Reference Manual
Dimensions
Radial Dimensions
: Create Radial Dimensions using the Cursor
The creation methods given here are applicable to RDIMs and PDIMs (Pitch Circle Dimensions). Refer to
for further information.
In addition to the basic creation method given in
, some style attributes can be defined by cursor interaction. Having created the RDIM/PDIM and defined its position,
DIM @
causes both dimension angle DDEG and text radius DTRAD to be defined in one go. (The dimension text origin is at the cursor crosshair position.) It does not modify DTOF.
