DRAW Reference Manual
Dimensions : Radial Dimensions
A Pitch Circle Dimension (PDIM) is another form of radial dimension. Refer to Pitch Circle Dimensions for further information.
Radial Dimensions have a dimension centre, defined by the DDNM (Design Data Name) attribute. The attribute is an attribute of the RDIM itself, this is normally defined by the origin of the element dimensioned. Refer to Radial Dimensions for exceptions to this. The value can be (for example) the origin of a CYLI or of a (filleted) PAVE (Panel Vertex).
The other principal attribute of an RDIM is the dimension attribute key, AKEY. The attribute is a word attribute that stores the code of a dimensional attribute of the design element type that is to be dimensioned. The default value of AKEY is DIAM.
