DRAW Reference Manual
Dimensions
Radial Dimensions
: Create Radial Dimensions
The RDIM is defined by the ON command plus optional AKEY syntax, for example:
NEW RDIM
- create RDIM element
ON ID @
- use cursor to define dimension centre
AKEY RADI
- change AKEY to give a radius dimension
In many cases it is unnecessary to define AKEY explicitly, since the DIAM setting gives a sensible result.
Although RDIM elements do not have p-point or p-line attributes it is possible to use p-point or p-line syntax to select the Design element. It is necessary for vertices (VERT, SEVE, PAVE) that cannot be picked directly by cursor. However, the Design element can be picked using the IDP @ command.
