Data Model
Pseudo Attributes
: Attribute Category: Detailing
Attribute Name
Data Type
Qualifier
Description
DGABRE
integer
Detailing Graphic Measure Line Absolute relativ flag
DGARLT
integer
Detailing Graphic Arc Length Dimension type
DGBAST
real
Triangle Base Line
DGCRAD
real
Detailing Graphic Circle Radius
DGDARK
integer
Detailing Graphic Display Criteria
DGDBED
real
Drawback End Diameter
DGDBGN
integer
Detailing Graphic Group number
DGDBSD
real
Drawback Start Diameter
DGELVT
real
Elevation Value
DGEXB
real
Detailing Graphic Distance to extension line begin
DGEXE
real
Detailing Graphic Distance to extension line end
DGFCOL
integer
Detailing Graphic Fill Color
DGFILL
integer
Detailing Graphic Fill flag
DGFLTV
integer
Detailing Graphic Line Pattern Number
DGFONT
integer
Detailing Graphic Font Number
DGFPAD
real
Pattern Repeat Factor
DGFPTY
integer
Pattern Type
DGFRME
integer
Detailing Graphic Text frame
DGFSHA
real
Detailing Graphic Shading Opacity
DGGAD
real
Detailing Graphic global angle direction
DGISEA
integer
Automatic Placement
DGITAL
logical
Detailing Graphic Text Attribute Italics
DGLAYN
integer
Detailing Graphic Layer Number
DGLCLO
integer
Close Polyline
DGLFIL
integer
Fill Polyline
DGLLEN
integer(3)
Text Line Lengths
DGLLIN
integer
Detailing Graphic Multi-line Text Length
DGLPFL
real
Detailing Graphic Line pitch first line
DGLPIA
real
Detailing Graphic Line pitch absolute
DGLSPA
real
Line Spacing
DGLTA
real
Detailing Graphic Line termination angle
DGLTIV
integer
Detailing Graphic Line Type invisible
DGLTL
real
Detailing Graphic Line termination length
DGLTSB
integer
Detailing Graphic Line termination begin
DGLTSE
integer
Detailing Graphic Line termination end
DGLTVI
integer
Detailing Graphic Visible Line Type number
DGLVSD
integer
Level Symbol Docking
DGLVST
integer
Level Symbol Type
DGMALI
logical
Detailing Graphic mark line flag
DGMATT
integer
Detailing Graphic Measure Line Text type
DGMLAT
integer
Detailing Graphic Angle Measure Line type
DGMLL
real
Detailing Graphic Marker Line Length
DGMTRL
real
Detailing Graphic Triangle Measure Line length
DGMTRT
integer
Detailing Graphic Triangle Measure Line type
DGNLIN
integer
Number of Lines
DGOLIN
integer
Number of Lines above Marker
DGORAN
real
Orientation Angle
DGPAAN
real
Pattern Angle
DGPACK
integer
Detailing Graphic Packed Word
DGPATT
integer
Detailing Graphic Line Pattern repeat factor
DGPDDR
element(100)
Reference to DGPDD Element
DGPEN
integer
Detailing Graphic Dimension Pen
DGPIV
integer
Detailing Graphic Pen invisible
DGPVI
integer
Detailing Graphic Pen visible
DGRADI
real(32)
List of radius
DGRDP
integer
Detailing Graphic Radius dimension position
DGRDT
integer
Detailing Graphic Radius dimension type
DGSCAL
real
Scaling Factor
DGSEGT
integer
Detailing Graphic Segment Type
DGSHAD
integer
Shading
DGSMH
real
Detailing Graphic Sm_Sysm height
DGSMW
real
Detailing Graphic Sm_Sysm width
DGTALI
integer
Detailing Graphic text alignment
DGTANG
real
Detailing Graphic text angle
DGTATB
integer
DGTCOL
integer
Detailing Graphic Text Color
DGTPLP
integer
Text Position on Level Point
DGTPOS
integer
Detailing Graphic Text position
DGTTOM
integer
Detailing Graphic text position related to mark out point
DGTXAN
integer
Detailing Graphic Text Anchor
DGTXB
real
Detailing Graphic Distance to text begin
DGTXE
real
Detailing Graphic Distance to text end
DGTXLI
integer
Detailing Graphic Flag for the lift of the last decimal number
DGTXRF
element(100)
Reference to DTTXTS Element
DGTXST
integer
Detailing Graphic Text Attribute style
DGTXT
string(80)
Display Text
DGTYPE
integer
Detailing Graphic Type
DGUSOF
real
Detailing Graphic underscore offset
DGWCIR
integer
Girth Weld Flag
DGWFLG
integer
Shop Weld Flag
DGWNTX
integer
Number of Weld Spec Texts
DGWNUM
integer
Number of Waves
DGWSCA
real
Z3 Window Scale
DGWSLS
integer
Detailing Graphic Welding Symbol Left side flag
DGWSOS
integer
Detailing Graphic Welding Symbol Other side flag
DGWSSN
integer
Detailing Graphic Welding Symbol Number
DGZART
integer
Detailing Graphic Drawing Type
DTADHO
integer
Bolting: Additional hole type
DTADPU
integer
Bolting Centre Punch Type
DTAREA
real
Area
DTAUTW
integer
Clamping Length Balancing Mode
DTBCKD
datetime(2)
Detailing Job Backup Date
DTBNAM
string(32)
Detailing Model Bolt Name
DTBNDB
string(32)
Detailing Model Bolt Name for Database
DTBNDR
string(32)
Detailing Model Bolt Name for Drawings
DTCATR
string(10)
Bolt Set Component Catalogue Numbers
DTCITY
string(80)
Detailing Address City
DTCLMA
real
Bolt Clamping Length (maximum)
DTCLMI
real
Bolt Clamping Length (minimum)
DTCLML
real
Bolt Clamping Length (calculated)
DTCLWA
real
Bolting Washer Clearance
DTCNTY
string(80)
Detailing Address Country
DTCSAG
real
Sink Hole Angle
DTCSDA
real
Sink Hole Diameter 1
DTCSDB
real
Sink Hole Diameter 2
DTCSDC
real
Sink Hole Diameter 3
DTCSHD
real
Sink Hole Dimension Head
DTCSIV
logical
Countersunk Bolt
DTCSNU
real
Sink Hole Dimension Nut
DTCTLN
real
Detailing Item Cut Length
DTDLIM
logical
Blind Hole Bolt
DTDMAT
logical
Clamp Length Calculation Flag
DTFTHK
real
Detailing Element Flange Thickness
DTGATT
real(10)
Detailing Model Attributes Real part
DTGNIF
integer
Bolt Hole Orientation Mode
DTGRADE
string(32)
Detailing Material Grade
DTHDHE
real
Bolt Header Height
DTHEIG
real
Detailing Element Height
DTHOTY
integer
Bolting Hole Type
DTLNAM
real
Detailing Item Length after Marking
DTLNGE
real
Detailing Item generated Length
DTMDFD
string(19)
Modified Date/Time
DTMIND
integer
Bolt Connection Processing Mode
DTMTYP
integer
M3 Connection Type
DTNUMB
integer
Detailing Model Element ident number
DTOHDD
real
Outside Bolt Header Diameter
DTOPOS
integer
Detailing Element Order Item Number
DTPROT
real
Bolt Protrusion
DTPUNI
integer
Bolt Packing Unit
DTRADA
real
Detailing Element Fillet Radius 1
DTRADB
real
Detailing Element Fillet Radius 2
DTRADC
real
Detailing Element Fillet Radius 3
DTRDAT
real(100)
DTROOA
real
Detailing Element Root Dimension 1
DTROOB
real
Detailing Element Root Dimension 2
DTROOC
real
Detailing Element Root Dimension 3
DTRWHG
real
Detailing Element Remaining Webbing Height
DTSAAS
real
Detailing weld throat depth (arrow side)
DTSAOS
real
Detailing weld throat depth other side
DTSCAN
logical
Bolt Hole Investigation Flag
DTSEFL
integer(100)
Detailing Model Relation Secondaries Flags
DTSKEY
string(32)
Bolt Standard Key
DTSMAT
logical
Include Bolt Mounting Material
DTSNUM
integer
Section number (cladding)
DTSPOS
integer
Start number for marking
DTSTAT
integer
Detailing Element Status
DTSTYP
integer
Detailing Element Shape Type Code
DTSURF
string(32)
Detailing Surface Treatment
DTTAPE
integer
Tapered Washer Mode
DTTCNT
integer
Detailing Element Total Count
DTTLNU
integer
Number of truck load
DTTOTL
real
Total Bolt Length
DTTSNR
integer
Detailing Element Phase Number
DTTXNX
integer
Fabrication model element text sequence number
DTTXRF
element(100)
Bocad Detailing Text Reference
DTUNIT
integer
Bolt Dimension Units
DTVBKY
string(32)
Bolt Fastener Table Key
DTVIDD
logical
Bolt always as 3D body
DTWGHT
real
Weight
DTWIDT
real
Detailing Element Width
DTWSIZ
real
Bolt Header Wrench Size
DTWTHK
real
Detailing Element Webbing Thickness
DTXVEC
dir
Detailing View Volume X-Axis
DTYVEC
dir
Detailing View Volume Y-Axis
DTZGRD
element
Detailing Zone Primary Grid
DTZNUM
integer
Bocad Detailing Zone Number
DTZPLN
element
Detailing Zone View Volume
DTZPOS
real
Z Offset of the view plane
DTZVEC
dir
Detailing View Volume Z-Axis
FSPMNU
integer
Factory Standard Part Mark Number
