Data Model
Pseudo Attributes
Pseudo Attributes
Attribute Category
Attribute Name
Data Type
Qualifier
Description
AGATYPE
string(120)
Auto Grid Annotation Type (as text)
AGDCLOSED
string(120)
Auto Grid Annotation Closed Dimensions (as text)
AGDOFFSET
string(80)
Auto Grid Annotation Dimension Offset
AGDOOFFSET
string(80)
Auto Grid Annotation Overall Dimension Offset
AGDOVR
string(120)
Auto Grid Annotation Overall Dimensions (as text)
AGDVRT
string(120)
Auto Grid Annotation Vertical Dimensions (as text)
AGLOFFSET
string(80)
Auto Grid Annotation Label offset
AGMODE
string(120)
Auto Grid Annotation Mode (as text)
AGSIDE
string(120)
Auto Grid Annotation Sides
ALIST
element(500)
APOFTX
string(80)
Leaderline attachment point text
ASDIM
real(3)
Assembly dimension
ATTSIZE
integer
attr
Actual size of attribute
AUTCOL
real(3)
Design rgb autocolour
BFCRGB
integer(4)
RGB backface colour
BPOFTX
string(80)
Leader bend point offset text
CABGAP
real
cable gap on cabletray as multiple of OUTD
CBSTA
string(700)
integer
Cable routing status text
CCOREF
element
Cable core set reference
CHCRGB
integer(4)
RGB dimension crosshairs colour
CHEITX
string(80)
Character height text
CHOSTX
string(80)
Crosshairs overshoot text
CLAI
integer
Claim mode
CLANAM
string array(10)
Class Name
CLMRGB
integer(4)
RGB column colour
CLNRGB
integer(4)
RGB centreline colour
CLOSEFLAG
logical
True if branch is closed
CLSNAM
string(120)
Class Name
COLRGB
integer(4)
RGB colour
COMPTYPE
word
Type of component
CONERF
element
Connection End Ref
CONSRF
element
Connection Start Ref
CONSUPPORTS
element(500)
All connected supports to the element tree under an element
CPOFTX
string(80)
Leaderline connection point text
CREF
element
Connection reference
CSPATX
string(80)
Character spacing factor text
CTXTPS
string(120)
Connector Text Position (as text)
DAENABLED
string(10)
Enable Autolabels for view (as text)
DATE
string(12)
Date
DBLNKP
logical
Linked Documents (DB) distribution flag
DCONFLAGS
string(120)
Draw Connector Flags
DDEGTX
string(80)
Radial dimension angle text
DFLT
string(500)
Default value for the attribute
DISPNN
string(120)
Display Name
DLCNTMODE
string(20)
Dimension line continuous mode (as text)
DLNRGB
integer(4)
RGB dimension line colour
DMSPTX
string(80)
Dimension spacing text
DPOFF
real
Dimension point offset
DRFLOW
string(20)
Draw Flow (as text)
DRMXTL
integer
Draft general max text length
DSHANG
real
Draft absolute sheet angle
DSHPOS
pos
Draft sheet position derived from 3d
DSIFIL
string(2000)
Datasheet Instance filename
DTCHTX
string(80)
Dim text char height text
DTERID
integer
Dimension terminator ID
DTLHTX
string(80)
Dimension text letter height text
DTOFTX
string(80)
Dimension text offset text
DTRATX
string(80)
Dimension text radius text
DTXRGB
integer(4)
RGB dimension text colour
ELEVAT
real
Elevation
ENDRFARRAY
element(100)
ENDATUM reference array
EXEXTN
real
Exit Extension
EXTNO
integer
Extract number
FABLOC
word
Fabrication location
FASTYP
word
Fastener Type
FEMCOL
integer
FEM image object colour
FFCRGB
integer(4)
RGB front face colour
FILRGB
integer(4)
RGB fill colour
FSETWE
real
Fastener Set Weight
FTERID
integer
First terminator ID
FULLID
string(20)
Full ID Plane
GAPALL
string(1000)
Gap Allowance
GATEHEIGHT
real
Gate Height
GATEWD
real
Gate Height
GBOXTX
string(80)
Box gap text
GENTYP
word
Type of geometry
GPRTRE
element(100)
Gpart reference
GRDID
string(20)
Grid plane index
GRDLBL
string(120)
Planes Label
HANOFFSET
pos
HANCI cached position offset
HANPOSITION
pos
Support cached position
HDIR
dir
Head direction
HEADH
real
Head duct height
HEADW
real
Head duct width
HPREF
element
Head point reference
IBLNAM
string
Name of idealised block
IDPREF
string(20)
ID Prefix
IFCUID
string(160)
Universally unique identifier from external sources (in IFC format)
LADRGB
integer(4)
RGB laser drawing colour
LCTROL
logical
Controlled DB Flag
LDFLT
logical
logical default value for a UDA
LEVE
integer(2)
Drawing level
LEXREF
element
Draw Linked External Reference
LFGRGB
integer(4)
RGB glabel style frame colour
LFRRGB
integer(4)
RGB label frame colour
LHEITX
string(80)
Letter height text
LLCLTX
string(80)
Leader line clearance text
LLGRGB
integer(4)
RGB glabel style leader colour
LLNRGB
integer(4)
RGB leader line colour
LMDREF
element(20)
Back reference to demolition packages referencing laser survey
LMDSES
integer(10)
Session number of back reference to demolition packages referencing laser survey
LMDSYN
string(700)
Synchronisation state of AVEVA and laser survey databases
LOCRGB
integer(4)
Loop RGB colour
LSCSLS
logical
Logical sheet changed since last save
LSPATX
string(80)
LTERID
integer
Label terminator ID
LVAR
logical
Variant Flag
LZERGB
integer(4)
RGB layer 0 colour
LZLSTY
integer
Layer 0 linestyle
LZPRIN
logical
Layer 0 printability flag
LZVIS
logical
Layer 0 visibility flag
MAXARE
real
Maximum area
MFFIND
element
Find Manufacturingpackage folder
MLNRGB
integer(4)
RGB member line colour
MODID
string(2000)
Used by laser driver to identify external laser data
MPFIND
element
MPKGFD
element
MRKRGB
integer(4)
RGB marker colour
MSGUID
string(160)
Universally unique identifier from external sources (in MS format)
MSTYID
integer
Marker style
MSTYSZ
real
Marker size
MTLCHE
string(80)
Matchline text character height as text
MTLLST
integer
Matchline linestyle
MTLRGB
integer(4)
RGB matchline colour
MTTRGB
integer(4)
RGB matchline text colour
NANGLE
real
North angle
NDFLT
real
Numeric default value for a UDA
NPPT
integer
Ppoint number
NPSIDE
string(80)
Side of nested part
NUMBDB
integer
DB number
OBFRGB
integer(4)
RGB obscured face colour
OCONE
integer
Objectcode 1
OLNRGB
integer(4)
RGB outline colour
ORDARE
real
Surface Area
ORDWEI
real
Order Weight
OSHTTX
string(80)
Overshoot text
OVCWIDTH
real
Overall cables width
PAAX
string(30)
Direction of axis
PAFRGB
integer(4)
RGB plot action from colour
PATRGB
integer(4)
RGB plot action to colour
PAXI
string(30)
Axial direction
PBAX
string(30)
Direction
PCAX
string(30)
Direction of C offset
PICRGB
integer(4)
RGB picture current colour
PINRGB
integer(4)
RGB pipe insulation colour
PKDI
real
Proportional distance along Pline
PKEY
word
Pline identifier key
PLCLTX
string(80)
Projection line clearance text
PLCRGB
integer(4)
RGB projection line colour
PLNRGB
integer(4)
RGB pline colour
PLSPTX
string(80)
Proj line text line-spacing text
POSL
word
Positioning line
PRBMAR
real
Primitive blanking margin
PRBMTX
string(80)
Primitive blanking margin text
PTCHTX
string(80)
Proj text char height text
PTFA
element(3)
Point references
PTLHTX
string(80)
Projection text letter height text
PTOFTX
string(80)
Projection line text offset text
PTRF
element
Point reference
PTXRGB
integer(4)
RGB projection text colour
PTYP
word
Property type
PZAXI
string(30)
Alignment axial direction
RLTRGB
integer(4)
RGB ruler long tick colour
RMTRGB
integer(4)
RGB ruler medium tick colour
ROWRGB
integer(4)
RGB row colour
RSTRGB
integer(4)
RGB ruler short tick colour
SCALAX
string(120)
Symbol Scale Axis (as text)
SCHED
string(10)
Piping Schedule
SCOSLX
integer(500)
Access Control scope
SCRAPT
real
Total scrap of raw plate area
SCRAPU
real
Total scrap of used raw plate area
SEALEV
real
Sea level height
SMBFLG
string(120)
Symbol extensible flag (as text)
SYMCNA
element(1000)
Symbol Connection Array
TABCLN
string array(10)
Tabite Class Name
TABREF
element(100)
Tabite reference
TAILH
real
Tail duct height
TAILW
real
Tail duct width
TATYPE
string(10)
Text answer type
TDATUM
pos
Definition of a specific point on earth
TDIR
dir
Tail direction
TPREF
element
Tail point reference
TREADD
real
Tread Depth
TRUNTX
string(80)
Truncation value (+ve) or percentage (-ve) text
TSIZTX
string(80)
Terminator size text
TWIDTH
real
Tread Width
TXGRGB
integer(4)
RGB glabel style text colour
TXTRGB
integer(4)
RGB text colour
UDIRECTION
dir
Up axis direction
UDNA
string(120)
User defined name
UPRLEN
real
Used profile length
UUID
string(36)
UUIDREF
element(500)
word
Universally unique identifier references
VENID
string(120)
Driver definition used to access external laser survey
VFRLST
integer
View frame linestyle
VFRRGB
integer(4)
RGB view frame colour
VLOCDI
dir
integer
View location plane direction
VLOCPO
pos
integer
View location plane position
VSIRGB
integer(4)
RGB view Section Indicator colour
WGAP
real
Weld Gap
WLNGTH
real
Weld Length
WTYPE
word
Weld type
XOFF
real
X-offset
YOFF
real
Y-offset
ZDIS
real
Position in section
