Common Functionality
Editor : Popup Menus on the Component Modification Handle : Rotation Handle
Displays the Rotate Selection About X, Y or Z window which allows you to specify an angle through which to rotate the Rotation Handle.
Clicking Preview allows you to see the proposed change in the graphical view. Click OK to accept the rotation or Cancel to close the window without rotating the element.
Displays the Enter Direction For Z Axis window which allows you to align the handle with a specified direction, or as close as possible to the given direction, about the axis of the pipe.
Click OK to accept the change or Cancel to close the window without changing the element.
