Common Functionality
Editor
Graphical Component Modification (GCM)
: Operations in GCM
Operations in GCM
The Component Modification Handle has two parts:
Movement
Rotation
Movement
The movement handle is used to move the selected components within the constraints of the of the Pipe route that the selected Components exist in.
The handle can be dragged by clicking and moving the mouse pointer. The legs that the selection can be dragged into are highlighted with a turquoise line (see above figure). By default, the handle moves in multiples of the currently defined
linear increments
. Clicking the left mouse button again positions the Graphical Selection.
When dragging, clicking the right mouse button presents you with a context-sensitive menu which relates to the direction and rotation of the handle, refer to
Popup Menus on the Component Modification Handle
Feature Highlighting
With Feature Highlighting
On
, dragging causes features such as p-points or p-lines to be highlighted when the pointer moves across them. Highlighted features can then be ‘snapped' to.
As the alignment with a feature invariably relates to the leg the Components are in, when feature highlighting is active the drag movement is constrained to lie along the leg the selected Component is currently in, not the whole pipe route. This prevents the inadvertent repositioning of Components into a different leg when trying to align with a feature.
When no feature is found initially, the handle moves using the default movement increments until a feature is identified. Selected Components cannot moved past either end of the pipe leg they are within.
Where a derived position is not within the bounds of the leg or cannot physically fit within a segment of a leg, the selected Components are positioned at the nearest extent of the leg closest to the derived position. Feedback is given to indicate that the positions of the items are not in alignment with the identified feature.
Where there is more than one position solution, the system has default behaviour to derive the initial position. However, it is possible to cycle through the possible positions and choose the desired one. The P hotkey is used for this.
Subsequent feature identification within the same drag uses the last solution type to derive the position, where possible. If there is no position solution to the feature selection, the system reverts to its default behaviour.
Once a drag has been initiated, you can finely adjust the positioning of the selected Components using hotkeys. You can ‘nudge’ the manipulation handle when dragging in a linear direction, using the numeric keypad + and ‑ keys. This moves the handle by + or ‑ the current linear increment.
In a similar way to nudging a Component you can nudge the position of the handle both by the default linear increment for major positioning, and by a fine value for accurate positioning (e.g. clearance from surfaces). To facilitate this a ‘fine nudge’ setting is available, where the granularity of the movement is less than that of the current linear increments.
Linear increments are controlled from the
Set Increments
window, Refer to
Increments
for further information.
Similar to the nudging using the + and ‑ hotkeys, the fine adjustment uses the arrow keys on the numeric keypad (or the numeric keypad 2 and 8 keys when Num Lock is ‘off’).
Once a nudge has been performed, moving the mouse has no effect. Nudging restricts the movement within bounds of the leg or segment of leg that the selected Components are within. Nudging does not take the selected Components past an inline Component or change in direction.
Rotation
The Rotation Handle allows you to rotate interactively the selected Components about the centreline of the Pipe that the handle is positioned on.
Component before rotating
Component after rotation
The Rotation Handle (and the graphical selection it is attached to) can be dragged by clicking and moving the mouse pointer, and allows a full 360° rotation drag about the centreline of the pipe. Clicking the left mouse button again positions the graphical selection.
Clicking with the right mouse button presents you with a context-sensitive menu which relates to the direction and rotation of the handle, see
Use of Feature Highlighting with the Rotation Handle is similar to using Feature Highlighting with the Movement Handle, see
When performing a free rotate, if feature highlighting is active but no feature is identified, the rotation uses the currently defined angular increment value. When a feature is identified, the handle is aligned in the appropriate manner, dependent on the feature identified. See
and
Hotkeys
for details of shortcut menu and hotkey options available when manipulating the rotation handle.
Nudging the Handle
Once a drag has been started, you can adjust the derived angular offset using the + and ‑ hot keys for the rotation handle.
As with moving, if a direction is derived from an alignment with a feature, using the nudge increments the rotation from the derived direction.
The Rotation Handle can be ‘nudged’ in the same way as the Linear Handle. Once a drag has been started using the primary or secondary mouse button, you can finely adjust the positioning of the selected Components using hotkeys. You can ‘nudge’ the manipulation handle when dragging in a linear direction, using the numeric keypad + and ‑ keys. This moves the handle by + or ‑ the current linear increment.
Repositioning the Handle
The default position of the Rotation Handle is at the origin of the Component initially selected when defining the selection. Identifying another Component in the selection repositions the handle to the origin of the identified item.
In some instances you will want to reposition the handle at a position which does not correspond to the origin of a Component. You can reposition the handle to the extremities of the selected Components via a pop-up menu on the movement handle:
Arrive of selection
Leave of selection
