Transaction Messages displays the transaction message history for the selected command within the Transaction Messages window. Refer to Viewing Transaction Messages for further information.
Flag displays the Command Transaction Flag window, where you can define its own Flag
The default Flag Text is Follow Up. Flagging a command transaction is useful if you want to find it again later. For example, if the daemon runs overnight, you may want to return to a command transaction on the following day to check its progress. Select the Display flagged commands only check box on the Command Transactions window to display flagged command transactions only.
