Common Functionality
Laser
Demolition of Laser Data
: Apply Demolition Package
Removes laser survey data within a demolition package, ensuring that the 3D model is consistent with the as-built condition of the asset. The demolition package status must be set to demolition ready before the demolition process can be completed.
It is recommended to display the Demolition Browser when applying modifications to the demolition package. The current status of the demolition package, including any information as to why the demolition cannot be applied, displays at the bottom of the
Laser Volumes - All Views
window. Refer to
Demolition Browser
for further information.
Detail Laser Data
Click to optimise the display resolution of the laser survey within the demolition set or demolition package volume.
Repeat the command to turn off the display optimisation.
Highlight Laser Data
Click to highlight detailed laser survey data within the demolition set or demolition package volume.
The default highlight colour is pink and cannot be modified.
Repeat the command to remove the highlight from the detailed laser survey data volume.
Mask Laser Data
Click to remove detailed laser survey data within the demolition set or demolition package volume.
Repeat the command to remove the mask from the detailed laser survey data volume.
Ready
The functionality available to apply the demolition package is explained. Refer to
Demolition
Ready
Click to apply the demolition ready
status to the currently selected demolition package or demolition set.
Repeat the command to remove the demolition ready
status from the currently selected demolition package or demolition set.
Once the demolition status has been set to demolition ready, you must click
Save Work
prior to demolition.
Demolition
Click to remove the laser survey data within the currently selected demolition package or demolition set.
Repeat the command to restore the laser survey data within the currently selected demolition package or demolition set.
