Common Functionality
Laser
: Demolition of Laser Data
Creates demolition packages to remove demolished or unwanted laser survey data, ensuring that the 3D model is consistent with the as-built condition of the asset.
To ensure the as-built condition of the asset, it is necessary to remove demolished items from the laser survey. Not only is it necessary to ensure the laser survey is kept up to date, it is necessary to ensure all users accessing the laser survey can see demolished laser data at all sites.
The demolition of laser survey data is managed by storing the geometric definition of the demolition in conjunction with a reference to the laser survey (XGEOM). The demolition package is stored in the Design database and allows organisations to integrate demolition data into the modelling processes along with other model elements. The demolition package can be transmitted between offices using AVEVA Global Server, ensuring that when a demolition is applied, the demolition package becomes available to all other offices. Using AVEVA Global Server to transfer the demolition package saves considerable time and bandwidth by removing the need to transfer the laser survey.
The demolition package does not delete the laser survey data, allowing it to be restored if required.
If the demolition package is modified, status information displays on the Demolition Browser and the Messages window.
