Input a value in the field to modify the name. If the name value is unset, the demolition package name is inherited from the owning element.
The direction can be defined in East, West, North, South, Up and Down directions using the drop-down lists.
Select the Lock check box to lock the selected direction.
You are prompted to Pick Position (Distance [0]) Snap :
The Positioning Control window displays by default, the Laser Data filter must be selected to pick a position within the laser survey. Refer to Positioning Control for further information.
The Select laser survey to reference window also displays if a laser survey is not displayed in the 3D view when the demolition package is created.
