Common Functionality
Laser
Demolition of Laser Data
: Demolition Hierarchy
All database elements are owned by other elements, therefore elements must be created in a strict order. A defined database structure is used for the laser demolition functionality.
Below the World level in the Model application, the demolition specific elements are:
Demolition World (DEMOWL)
Demolition World (DEMOWL) elements are administrative and can own a number of Demolition Set (DEMOSE) elements.
Demolition Set (DEMOSE) elements are owned by DEMOWL elements. These elements are administrative elements used to define the demolition structure and can own a number of Demolition Package (DEMOPA) elements.
Demolition Package (DEMOPA) elements are owned by DEMOSE elements. These elements are container elements for demolition primitives and can own primitive elements.
Primitives
Primitives are used to define the limits of the demolition area. For example, a cube (BOX) element or a cylinder (ACYLIN) element. The volume within the primitive is used to remove demolished laser survey data from the 3D view.
