Input a value in the field to modify the name. If the name value is unset, the area definition name is inherited from the owning element.
The direction can be defined in East, West, North, South, Up and Down directions using the drop-down lists.
Select the Lock check box to lock the selected direction.
You are prompted to Pick Position (Distance [0]) Snap :
The Positioning Control window displays by default, Refer to Positioning Control for further information.
