Common Functionality
Design Aids : Annotations : Create Text Label
Input values in the dimension fields and press Enter or click to identify the label attachment position.
Input values in the dimension fields and press Enter or click to identify the text start position.
Input a dimensional value in the field and press Enter or click to identify the text height.
Throughout the creation process you can press ESC to cancel the command. Additional functionality is also available.
