Common Functionality
Design Aids : Reference Grids : Reference Grid Annotations
The Label property defines the annotation type. By default, the property is defined as Axis along the X axis and Row along the Y axis.
The Label property defines the prefix text for the label. By default, the property is defined as Elev along the Z axis. Input a value in the field to modify the annotation label. For example, input HEI in the field to start the grid annotation with HEI 1.
The Start ID value is only used if the grid elevation label display is set to Plane ID.
The Step ID value is only used if the grid elevation label display is set to Plane ID.
The ID prefix property is a non-editable property. The value is inherited from the label property of the owning GRIDFA or GRIDEL element.
The Full ID plane property is a non-editable property. The value is inherited from the combined properties of the ID Prefix and ID Plane attributes.
You are prompted to Pick Refgrid to reapply labels on grid planes
