Common Functionality
Design Aids : Reference Grids : Create Radial Grid Plane
You are prompted to Select reference grid plane
You are then prompted to Rotation or <finish>
Input an angular value in the field and press Enter or click to identify a grid plane position along the axis.
Input F at the prompt and press Enter to end the command.
Throughout the grid plane creation process you can press ESC to cancel the command. Additional functionality is also available.
