Common Functionality
Design Aids
Reference Grids
: Create Grid Plane
Create Grid Plane
Creates a grid plane on the currently selected reference grid.
A new grid plane is created from an existing grid plane. By default, the name of the new grid plane is defined from the name of the reference grid.
A new grid plane can only be created from within grid edit mode. Refer to
Grid Edit Mode
for further information.
You are prompted to
Select reference grid plane
Click to identify an existing grid plane on the same axis as the new grid plane.
You are then prompted to
Specify offset or <Finish>
Input a dimensional value in the field and press
Enter
or click to identify a grid plane position along the axis.
The prompt is repeated, allowing you to create multiple grid planes along the selected axis.
Input
F
at the prompt and press
Enter
to end the command.
Throughout the grid plane creation process you can press
ESC
to cancel the command. Additional functionality is also available.
Finish
Press the down arrow key and select
Finish
to end the command.
The new grid plane elements display in the Model Explorer.
Related Topics
Non-Routed Item
