Common Functionality
Design Aids
Reference Grids
: Grid Edit Mode
Grid Edit Mode
Modifies multiple planes of a reference grid in an environment that does not allow you to select 3D model elements.
When grid edit mode is entered, all 3D model elements become inactive and additional grid plane modification functionality becomes available.
Input the command
IN
and press
Enter
to enter grid edit mode.
You are prompted to
Select Objects
The prompt does not display if the reference grid elements are already selected.
Click to identify the reference grids to be modified and press
Enter
. The selected grids are highlighted in the 3D view.
Input the command
OUT
and press
Enter
to exit grid edit mode
