Defines a project main reference grid. Refer to Main Reference Grid for further information.
Input True in the field to lock the element for modification.
Input False in the field to unlock the grid for modification.
A main reference grid is the default reference grid for a grid ruler. Refer to Grid Ruler for further information.
A hull view location can be defined. Refer to Create Hull View for further information.
The position of the element, relative to the nearest grid plane along the X axis, displays in the Command Window. For example:
The position of the element, relative to the nearest grid plane along the Y axis, displays in the Command Window. For example:
The position of the element, relative to grid origin along the Z axis, displays in the Command Window. For example:
