Press the down arrow key and select Name to define the grid name.
You are prompted to Grid name
Input a unique name in the field and press Enter to name the grid.
Press the down arrow key and select Two corners to define the dimensions of the bottom or the top of the grid by specifying two corner points.
Press the down arrow key and select Origin to define the grid origin position.
You are prompted to Specify grid origin or
Input values in the dimension fields and press Enter or click to identify the grid origin position.
Press the down arrow key and select Corner to define the grid dimensions of the bottom of the grid by specifying a corner point.
You are prompted to Specify the bottom corner or
Input values in the dimension fields and press Enter or click to identify the corner point.
Press the down arrow key and select Dimensions to define the dimensions of the bottom or the top of the grid by specifying a dimension point measured from the grid origin.
Press the down arrow key and select Next to proceed to the next grid creation process.
