Press the down arrow key and select Name to define the grid name.
You are prompted to Grid name
Input a unique name in the field and press Enter to name the grid.
Press the down arrow key and select Diameter to define a cylindrical plane using a diameter value.
Press the down arrow key and select Radius to define a cylindrical plane using a radius value.
Press the down arrow key and select Next to proceed to the next grid creation process.
Press the down arrow key and select Fill to create multiple grid planes that are separated by a defined angular value.
Press the down arrow key and select Absolute to define a grid plane with a distance value measured from the grid origin.
Press the down arrow key and select Relative to define a grid plane with a distance value measured from the previously created grid plane.
