Press the down arrow key and select Name to define the grid name.
You are prompted to Specify grid name
Input a unique name in the field and press Enter to name the grid.
Press the down arrow key and select Absolute to define a grid plane with a distance value measured from the grid origin.
Press the down arrow key and select Relative to define a grid plane with a distance value measured from the previously created grid plane.
Press the down arrow key and select Y to create the Y axis of the grid.
You are prompted to Specify Step along Y axis
Input a dimensional value in the field and press Enter or click to identify a plane position along the Y axis.
Press the down arrow key and select Z to create the Z axis of the grid.
You are prompted to Specify Step along Z axis or <Finish>
Input a dimensional value in the field and press Enter or click to identify a plane position along the Z axis.
