Common Functionality
Getting Started
Shortcut Keys
: CIE In-Canvas Commands
When using the In-canvas command prompt the following commands can be typed directly in:
In-Canvas Command
Description
AIDARC
Invokes function to create AID type Arc.
AIDBIS
Invokes function to create an AIDLIN bisecting between two non-parallel AIDLINs.
AIDCIR
Invokes function to create AID type Circle.
AIDFIL
Invokes function to create filleting AIDARC connecting two non-parallel AIDLINs.
AIDLIN or L
Invokes function to create AID type Line.
AIDPOI
Invokes function to create AID type Point.
AIDTAN
Invokes function to create an AIDLIN tangential to two circles which are non concentric.
AIDTEXT
Invokes function to create AID type Text.
ANGLE
To calculate angle between any two entities.
BRACING
To specify bracing gaps for existing diagonal elements or members.
CAMERA
Enables to lock view wrt an object. Also disables 3D orbit mode when it is enabled.
CANCEL
Cancels any current operation in-progress.
COPY or CO
Invokes function to copy selected entities with respect to a base point selected and also paste them at required locations in a loop.
COPYBASE
Invokes function to copy selected entities with respect to a base point selected.
COPYCLIP
Invokes function to copy selected entities without any base point.
CONNECT
Enables function to connect any two GENSECs.
CUTBASE
Invokes function to CUT/PASTE selected entities with respect to a base point selected.
CUTCLIP
Invokes function to CUT/PASTE selected entities.
D or LINDIM
Invokes function to create db type Linear Dimension.
DELETE
To delete selected entities.
DISCONNECT
Enables function to disconnect any two connected GENSECs.
DIST or DI
To calculate distance between any two entities.
EM or EDITMODE
Triggers Edit Mode.
ENDATUM
Create a ENDATU Fixing at selected End of GENSEC. Specs can be set only for old BS Column and Beam type profiles.
EXTEND
Enables function to extend the end of a structural element to a reference element.
FILLET
To create a Fillet between two non-connected structural elements.
FLY
Enable FLY mode operation.
FORCETRIM
To trim an attached GENSEC to selective Pline of Owning GENSEC.
FOVY
Enables option to enter new Vertical field-of-view angle (Projection mode should be in Perspective to enable this option).
GENSECDEF
Triggers function to set default specification wrt existing GENSEC.
GFITT_CRE
Enable function to create a GENSEC Fitting.
GFITT_MOD
Enable function to modify a GENSEC Fitting.
GRIDCY
Invokes function to create a new GRID CYLINDER for Radial Grid only in In-Mode.
GRIDID
Resets IDs of REFGRDs.
GRIDPL
Invokes function to create a new GRID PLANE for REFGRD in IN-Mode (Currently works for a single REFGRD).
ID
Queries Coordinate Positions at snapped position.
IN
Triggers IN or Include mode.
JMOD
Enables you to modify joints on a SECTION.
LCS
Invokes operation to change Coordinate system between Local and World.
LINDIMA
Invokes function to create db type Aligned Dimensions.
LOOKROUND
Enables 3D Orbit mode option to look around a locked view in Perspective ProjMode.
M or MOVE
Invokes function to move entities with respect to a base point selected and also paste them at required locations in a loop.
MERGE
To merge two members of same element type.
MI or MIRROR
To mirror any selected Structural Elements by defining a Mirror Plane.
MITRE
Enables option to Mitre two ends of GENSECs.
MLABEL
Invokes a function that creates a Label in 3D Canvas.
MREDO
Enables you to REDO all previous actions or to desired number of actions.
NEXT
To go Forwards through Views.
OUT
Trigger OUT mode by exiting IN mode.
OUTALL
Takes you all the way out.
OSNAPD
Triggers Distance Snap Mode function.
P or PAN
Enables REALTIME PAN option.
PANARC
Enables function to Create a ARC PANEL using three point or two point methods.
PANCIRC
Enables function to Create a CIRCULAR PANEL with multiple options.
PANDIR
Pans View towards selected PLAN VIEW directions.
PANDISC
Enables function to Create a DISC PANEL using Center + or two point methods.
PANELNXTRDISC
Creates a Negative extrusion of a PANEL in Circular Shape in three different modes.
PANELNXTRMULT
Creates a Negative extrusion of a PANEL in Rectangular Shape using Multiple Points.
PANELNXTRRECT
Creates a Negative extrusion of a PANEL in Rectangular Shape using Two Points.
PANMULT
Enables function to Create a RECTANGULAR PANEL with multiple points.
PANOFFSET
Enables function to Create a an Offset Perimeter of PANEL with multiple points.
PANRECT
Enables function to Create a RECTANGULAR PANEL using two points.
PANRING
Enables function to Create a RING PANEL using three point to two point methods.
PASTECLIP
To paste any copied or cut elements that are available in current session.
PFITT_CRE
Enable function to create a PANEL Fitting.
PFITT_MOD
Enable function to modify a PANEL Fitting.
PLAN
Set the current View to Plan View mode.
PR or PROPERTIES
Open Property Window if not opened already in the application.
PREV
To go Back through Views.
PROJMODE
Toggles between Projection modes Orthogonal or Perspective.
RADIAL
Enables option to create a Radial Grid.
REDO
Redo any operation that was previously called back (Performed Undo).
REFGRD
Enables option to create a Reference Grid.
RO or ROTATE
Invokes function to rotate any object around any defined axis.
SCALE
To Scale a Structural Element by selecting a Base Point.
SECARC
Creates a ARC GENSEC and also gives multiple options to choose the way they are created.
SECCUR
Creates a Curved GENSEC and also gives multiple options to choose the way they are created.
SECRING
Creates a RING GENSEC and also gives multiple options to choose the way they are created.
SECTION
Creates a Straight GENSEC and gives multiple options to choose the way they are created.
SELALL
To select all the elements in 3D View.
SPLICE
To Splice any Structural Element(s) in multiple ways.
SPLIT
To split any Structural Element(s) in multiple ways.
STRETCH
To Stretch any Structural Element along a defined path.
TOWER
Enables option to create a Rectangular Tower Grid.
TOWERT
Enables option to create a Triangular Tower Grid.
U
To Undo any current operation.
UNDO
Enables you to UNDO all operation or to desired number of counts.
WALK
Enables you to WALK around a Model.
Z or ZOOM
Enables Zoom options.
-VIEW or -V
To change any View between Isometric or Orthographic or Plan View.
-PAN or -P
PANs view wrt base point selection.
3DO or 3DORBIT
Enables 3D Orbit mode.
