DRAW Administrator Guide
Pipe Spool Drawing Administration : Position and Populate Spool Drawing Backing Sheet : Backing Sheet Bar Code
To access the bar code font in AVEVA E3Dâ„¢, the Font attribute value must match the Font ID defined in the ADMIN module.
The process to insert a Barcode note element is explained as part of the process to insert an MtoTable note element, with the exception of the SpPurp and Function values. Refer to Backing Sheet MTO Table Note for further information.
In order for the note to be identified as a barcode, the SpPurp attribute must be set to BARC and the Function attribute set to unset.
