DRAW Administrator Guide
Pipe Spool Drawing Administration
: Position and Populate Spool Drawing Backing Sheet
Functionality is available to position and define information that is displayed on a spool drawing backing sheet.
To create a backing sheet, you must create a library element to store the backing sheet information. Refer to
Create Library
for further information.
You must then create a sheet library element to store backing sheet information. Refer to
Create Sheet Library
In order for the sheet library to be identified as a spool drawing sheet library, the
SpPurp
attribute must be set to
PSPOOL
You must then create a backing sheet element to store spool drawing information. Refer to
Create Backing Sheet
Note elements are required for the appearance of the backing sheet and are divided into manageable sections. For example, Title, Logo, MTO Table, Bending Table. Refer to
Notes
The LIBY, SHLB and BACK elements display containing NOTE elements.
The element naming conventions are important as well as the SPurpose and Function attributes.
The following backing sheet elements can be defined:
Backing Sheet Text
Backing Sheet Graphical Note
Backing Sheet Frame Note
Backing Sheet MTO Table Note
Backing Sheet MTO Table Entries Note
Ring Flange Allowance
Backing Sheet Bending Table Note
Backing Sheet Bending Table Entries Note
Backing Sheet Assembly Table Note
Backing Sheet Assembly Table Entries Note
Backing Sheet Welding Table Note
Backing Sheet Welding Table Entries Note
Backing Sheet Endpoint Table Note
Backing Sheet Endpoint Table Entries Note
Backing Sheet Spool Information Table Note
Backing Sheet Spool Information Table Entries Note
Backing Sheet Elbow Cut Table Note
Backing Sheet Elbow Cut Table Entries Note
Backing Sheet Reserved Areas Note
Backing Sheet Bar Code
