DRAW Administrator Guide
Pipe Spool Drawing Administration
Position and Populate Spool Drawing Backing Sheet
: Backing Sheet Reserved Areas Note
Reserved areas can be applied for each of the views that are applied by the drawing template.
The implementation of the ReservedAreas note element is not complete for the current release.
A spool information note element is named
ReservedAreas
In order for the note to be identified as a reserved area, the
SpPurp
attribute must be set to
TABLE
and the
Function
attribute set to
unset
Text elements are used to label each of the reserved areas on the backing sheet and can be added using the
window. Refer to
for further information.
Rectangle elements are used to define each of the reserved areas. Refer to
Draw Rectangles and Diamonds
The reserved areas display on the drawing canvas.
The new TEXP and RECT elements display in the Draw Explorer.
The final step is to deselect the
Lvisibility
attribute check box for the reserved area note element, the elements become hidden from view.
