In order for the note to be identified as a spool drawing endpoint table entry, the SpPurp attribute must be set to CELLS and the Function attribute set to ENDPOINT.
The EndpointATableEntries note element can be deleted if not required. Connection numbers do not display on the spool drawing if the EndpointATableEntries note is deleted.
