In order for the note to be identified as a spool drawing endpoint table, the SpPurp attribute must be set to TABLE and the Function attribute set to ENDPOINT.
The EndpointATable note element can be deleted if not required. Connection numbers do not display on the spool drawing if the EndpointATable note is deleted.
