DRAW Administrator Guide
Pipe Spool Drawing Administration
Position and Populate Spool Drawing Backing Sheet
: Backing Sheet Welding Table Note
A welding table note is used to represent welding table title data which requires additional administrative information.
A welding table note element is named
WeldingTable
The process to insert a
WeldingTable
note element is explained as part of the process to insert an
MtoTable
note element, with the exception of the
SpPurp
and
Function
values. Refer to
Backing Sheet MTO Table Note
for further information.
In order for the note to be identified as a spool drawing welding table, the
SpPurp
attribute must be set to
TABLE
and the
Function
attribute set to
WELDING
The welding table displays on the drawing canvas.
The new STRA and TEXP elements display in the Draw Explorer.
The final step is to deselect the
Lvisibility
attribute check box for the welding table note element, the elements become hidden from view.
