The ETEXT attribute value must not be changed. The attribute is used as a KEY for codes. Editing an expression on the Pipe Spool Admin window changes the ETEXT attribute.
In order for the note to be identified as a spool drawing bending table entry, the SpPurp attribute must be set to CELLS and the Function attribute set to BENDINGA.
