DRAW Administrator Guide
Pipe Spool Drawing Administration : Position and Populate Spool Drawing Backing Sheet : Backing Sheet Bending Table Note
The process to insert a BendingATable note element is explained as part of the process to insert an MtoTable note element, with the exception of the SpPurp and Function values. Refer to Backing Sheet MTO Table Note for further information.
In order for the note to be identified as a spool drawing bending table, the SpPurp attribute must be set to TABLE and the Function attribute set to BENDINGA.
The final step is to deselect the Lvisibility attribute check box for the bending table note element, the elements become hidden from view.
