DRAW Administrator Guide
Pipe Spool Drawing Administration
Position and Populate Spool Drawing Backing Sheet
: Ring Flange Allowance
Flanges contain a flange allowance value in the catalogue; the value can affect both MTO and assembly tables.
The example below displays a flange allowance value in the
Pipe Data Table
window.
The flange allowance can be queried for the for the currently selected flange, Enter
Q FLALLOW
in the
Command Window
. The example below displays the Flange Allowance as 31.8mm
The example below displays an MTO table indicating the quantity and build values of the currently selected flange.
The example below displays an assembly table indicating the flange allowance as a value of 32, this is derived from the quantity value minus the build value.
