DRAW Administrator Guide
Introduction
: DRAW Default Files
DRAW Default Files
The following is a summary of the default files supplied with the product. The files themselves contain additional information. The files are stored in the DFLTS folder.
General Default Files
Name
Description
DRA-GEN-SYSTEM
System defaults file
DRA-GEN-SYSTEM.IMP
System defaults file with imperial settings
DRA-GEN-SYSTEM.bak
System defaults file back-up copy
DRA-SETUP
User configurable setup file
DRA-GEN-FONTS
Font names file: four font names can be defined
DRA-GEN-TEXT
Sample intelligent text display for dynamic text
DRA-GEN-CLASHTEMP
Clash plotting macro template
DRA-GEN-DEFLAY
Layer setup macro: standard default
DRA-GEN-DIMLAY
Layer setup macro: dimension layers
DRA-GEN-HLDLAY
Layer setup macro: Hangers & Supports layers
DRA-GEN-LABLAY
Layer setup macro: label layers
DRA-GEN-MATLAY
Layer setup macro: matchline layers
DRA-GEN-NLLLAY
Layer setup macro: label layers with no leader lines
DRA-GEN-NOTLAY
Layer setup macro: note layers
DRA-GEN-PLTEXT
Projection-line text options
DRA-GEN-RADLAY
Layer setup macro: radial dimension layers
DRA-GEN-SYMLAY
Layer setup macro: symbol layers (2D SYMB)
DRA-GEN-TAGLAY
Layer setup macro: tagging layers (layers with reserved purpose TAG)
ADP Default Files
Name
Description
DRA-GENADP-EQUILOCN
General ADP defaults file for equipment location plans
DRA-GENADP-PIPING
General ADP defaults file for piping plan and elevation GAs
DRA-GENADP-PLOTPLAN
General ADP defaults file for plot plans
DRA-GENADP-SUPPORTS
General ADP Defaults file for Support drawings
DRA-ADP-BRANINLAY
Layer setup macro for ADP branch labels
DRA-ADP-DIM1LAY
Layer setup macro for ADP Type 1 dimensions
DRA-ADP-DIM2LAY
Layer setup macro for ADP Type 2 dimensions
DRA-ADP-DIM3LAY
Layer setup macro for ADP Type 3 dimensions
DRA-ADP-EQUICLLAY
Layer setup macro for ADP equipment centrelines
DRA-ADP-PESYMBLAY
Layer setup macro for ADP pipe end symbols
DRA-ADP-SCHEDLAY
Layer setup macro for ADP schedules
DRA-ADP-SCHEDSUPP
Layer setup macro for ADP Hanger and Support schedules
DRA-ADP-TAGLAY
Layer setup macro for ADP Tagging
DRA-ADP-DIM3LEFTATTS
Dimension setup macro for ADP TYPE 3 dimensions LEFT side of view
DRA-ADP-DIM3UPATTS
Dimension setup macro for ADP TYPE 3 dimensions UP side of view
DRA-SDADP-MACRO
Macro file for setting defaults for Steelwork Detailing ADP.
Hangers & Support Default Files
Name
Description
DRA-SUPP
Main H&S defaults
DRA-SUPP-HADLAY
Layer setup macro for hanger dimension layers
DRA-SUPP-HSMLAY
Layer setup macro for hanger material list layers
DRA-SUPP-SIBLAY
Layer setup macro for supported item BOM layers
DRA-SUPP-STBLAY
Layer setup macro for steelwork BOM layers
Detail View Default Files
Name
Description
DRA-LOC-LAYER
Detail layer setup macro for master view
DRA-LOC-NOTE
Default detail view note intelligent text for master view
DRA-LOC-NOTE-EXAMPLES
Examples of alternative detail view note intelligent texts for master view
DRA-DET-LAYER
Detail layer setup macro for new detail view
DRA-DET-NOTE
Default detail view note intelligent text for new detail view
DRA-DET-NOTE-EXAMPLES
Examples of alternative detail view note intelligent texts for new detail view
Radial Dimension Default Files
Name
Description
DRA-DIM-PDIM
PDIM setup macro, this macro is executed each time a PDIM is created
DRA-DIM-RDIM
RDIM setup macro, this macro is executed each time a RDIM is created
Miscellaneous Default Files
Name
Description
DRA-AUTONAME
File required for successful appware loading (for future use)
