DRAW Administrator Guide
Introduction
Introduction
The DRAW Administrator Guide is intended for Administrators responsible for setting up defaults and the Libraries used by the DRAW application.
It is assumed that you are already familiar with using DRAW to produce annotated drawings, and that you have attended a DRAW Administration training course.
You must be a member of the DRAWADMIN team in order to view the Administration options on the DRAW menus. Refer to
Administrative Access Rights
for further information.
Some general principles, which you need to understand before performing administrative functions in DRAW are:
Which aspects of DRAW are under your control.
What access rights you must have in the Project in order to be able to act as a DRAW administrator, and how to set these up.
When entering DRAW as an administrator the Admin tab displays in the application.
