Cable Trays User Guide
Cable Tray Components : Connect Component
To disconnect the component, or connect it to a different item, on the Cable Tray tab, in the Connect group, click Connection Ref. to display the Connection Reference window.
The current connection displays in the Connection Reference window, click Unset to disconnect the current connection.
You can input an element to in the Connection Reference field.
Click Apply to accept the change, Reset to remove all changes or Dismiss to close the Connection Reference window.
