Cable Trays
Cable Tray Components
Cable tray components are single elements used together to create a cable tray design.
It is usual for you to build up the cable tray design by adding components sequentially, starting at the branch head and positioning and orientating each component as they proceed until the branch tail is reached. You can insert a component into an existing sequence by navigating to the component immediately before the required location and then creating the new component.
There are many different combinations of cable trays that can be created, because of this the Cable Tray application uses a common layout for windows that are presented to you. The information can be applied to the same processes that are used to create all other types of cable tray components.
