Select the position axis from the Position drop-down lists, choose from East/West, North/South and Up/Down. You can then input the explicit position values in the Position fields.
You are prompted to Pick Head Position (Distance[0] Snap: to position the branch head or Pick Tail Position (Distance[0] Snap: to position the branch tail in the 3D graphical view.
Displays the Offset Head Position window to Offset the branch head or the Offset Tail Position window to Offset the branch tail.
You can then input the explicit offset values in the Offset fields.
An Open connection allows you to connect the branch head or branch tail to another branch.
A Boxing connection terminates the branch head or branch tail, connection to another branch is not available.
